Hey Guys,
I am from Germany and I am new here...
I built an LCD SLA and i want to use nanodlp.
At the moment i have problems to calibrate my "projector" (or in my case the LCD).
I use this LCD:
https://de.aliexpress.com/item/Single-H … b558f51e8b
The resolution of the display is 2048 x 1536 px.
Now what i have to do with the X/Y Resolution?
I entered 95.7micron but the pictures on the screen are to big.
I would be glad if anyone can help me... Thanks! :-)
No ideas?
You should measure width of projected image on tank floor and calculate x/y resolution.
thank you for your answer... but the real problem is, that every value i type in the settings or in the config.txt shows the same size on the screen.
For example:
I use an IPAD 9,7" LCD...
For 96µm the image is to big... but for example with 40µm the image is also the same size as before....
The way to the right calculation is clear... but this is so strange!
Do you have an idea?
You need to regenerate plates. As they do not get updated after resolution changes automatically.
Was there a solution to this? I am having the same problem. I'm trying the same screen and driver board and everything is zoomed in. Even the calibration matrix is only showing the centre. I've set the Horizontal Resolution to 2048 and vertical to 1536. x/y resolution to 97microns and y resolution to 0. I've done the same in the config.txt file. Any ideas?
Hi.. no sorry i have no solution till yet.
I switched to Creation Workshop, because no one here can help me. :-(
Let me know if you have an solution... :-)
