#1 2017-09-15 01:29:33
Doug
How to use Conditionals?
How to use conditional in nanodlp?
Like if, else , while, etc...
for exemple;
if Z current position < 0
set Z = 0
#2 2017-09-15 05:30:47
Re: How to use Conditionals?
[[PositionSet {([[CurrentPosition]]>0)*[[CurrentPosition]]}]]
It changes all negative positions to zero.
#3 2017-09-27 16:32:57
Doug
I need this for movements less than 0 and I need for movements more than 128
set Z = 0
and
if Z current position > 128
set Z = 128
How to do it?
#4 2017-09-28 05:13:46
[[PositionSet {([[CurrentPosition]]<128)*[[CurrentPosition]]+([[CurrentPosition]]>128)*128}]]
#5 2017-09-28 13:11:59
Doug
#6 2017-09-28 23:09:39
Doug
Another question, I don't want to make another thread
Whats the placeholder for Pinter Name, last Plate Name, last Print Time and last Resin Usage?
#7 2017-09-29 07:00:43
There is no access to named fields from gcode box. It will slow done gcode box processing so only limited number of fields are accessible from gcode boxes.
Workaround is to call external script from gcode box and from there you can have access to all variables by sending requests to different URL on nanodlp such as /status
#8 2017-09-29 10:47:02
Doug
I want this placeholders to use on Execute at end. to send notifications via pushbullet.
#9 2017-10-13 13:07:34
Doug
how can I get this formula to work?
(([[LayerNumber]] <=  5) * ([[SupportCureTime]] * 1) )
(([[LayerNumber]] <= 10) * ([[SupportCureTime]] * 0.75))
(([[LayerNumber]] <= 15) * ([[SupportCureTime]] * 0.50))
(([[LayerNumber]] <= 20) * ([[SupportCureTime]] * 0.25))
but if [[SupportCureTime]] <  [[CureTime]] use [[CureTime]]
#10 2017-10-13 13:21:37
You can use [[Net]] keyword to send pushbullet.
You should use {} to cover whole section which contains conditional or math to make it works.
#11 2017-10-13 13:38:34
Doug
how about the part ;
#12 2017-10-13 15:43:41
{ ([[CureTime]] <  [[SupportCureTime]]) * [[CureTime]] }
#13 2017-10-13 18:05:40
Doug
I tried this didnt work
{(  (([[LayerNumber]] <=  5) * ([[SupportCureTime]] * 1) )+(([[LayerNumber]] <= 10) * ([[SupportCureTime]] * 0.75))+(([[LayerNumber]]<= 15) * ([[SupportCureTime]] * 0.50))+(([[LayerNumber]] <= 20) * ([[SupportCureTime]] * 0.25)))+ ([[CureTime]] <=  [[SupportCureTime]]) * [[CureTime]] )}
Error
Math issue ((14 <= 5) * ([[SupportCureTime]] * 1) )+((14 <= 10) * ([[SupportCureTime]] * 0.75))+((14 <= 15) * ([[SupportCureTime]] * 0.50))+((14 <= 20) * ([[SupportCureTime]] * 0.25)) + ([[CureTime]] < [[SupportCureTime]]) * [[CureTime]]) -1 Invalid token ‘[’
#14 2017-10-13 21:36:19
As you see, [[CureTime]] and [[SupportCureTime]] are not replaced. I have checked out code. We do not support neither keywords.
#15 2017-10-16 13:53:57
Doug
What you suppose to use in dynamic cure times?
#16 2017-10-16 18:43:04
Mostly current layer, largest/smallest area and etc.
