Just got the PLEN2 DIY Kit.
Trying to update the firmware (latest pulled from, the Git repo) - using Arduino IDE 1.7.9 on OS X El Capitan 10.11.5.
Error compiling.
In file included from ExternalEEPROM.cpp:13:0:
/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/libraries/Wire/Wire.h: In static member function 'static char PLEN2::ExternalEEPROM::readSlot(unsigned int, char*, unsigned char)':
/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/libraries/Wire/Wire.h:59:13: note: candidate 1: uint8_t TwoWire::requestFrom(int, int)
uint8_t requestFrom(int, int);
/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/libraries/Wire/Wire.h:57:13: note: candidate 2: uint8_t TwoWire::requestFrom(uint8_t, uint8_t)
uint8_t requestFrom(uint8_t, uint8_t);
JointController.cpp: In member function 'void PLEN2::JointController::loadSettings()':
JointController.cpp:110:12: error: no match for 'operator[]' (operand types are 'EEPROMClass' and 'int')
if (EEPROM[INIT_FLAG_ADDRESS()] != INIT_FLAG_VALUE())
JointController.cpp:112:9: error: no match for 'operator[]' (operand types are 'EEPROMClass' and 'int')
EEPROM[INIT_FLAG_ADDRESS()] = INIT_FLAG_VALUE();
JointController.cpp:117:10: error: no match for 'operator[]' (operand types are 'EEPROMClass' and 'int')
EEPROM[SETTINGS_HEAD_ADDRESS() + index] = filler[index];
JointController.cpp:125:26: error: no match for 'operator[]' (operand types are 'EEPROMClass' and 'int')
filler[index] = EEPROM[SETTINGS_HEAD_ADDRESS() + index];
JointController.cpp: In member function 'void PLEN2::JointController::resetSettings()':
JointController.cpp:168:8: error: no match for 'operator[]' (operand types are 'EEPROMClass' and 'int')
JointController.cpp:173:9: error: no match for 'operator[]' (operand types are 'EEPROMClass' and 'int')
EEPROM[SETTINGS_HEAD_ADDRESS() + index] = pgm_read_byte(
JointController.cpp: In member function 'bool PLEN2::JointController::setMinAngle(unsigned char, int)':
JointController.cpp:290:9: error: no match for 'operator[]' (operand types are 'EEPROMClass' and 'int')
EEPROM[SETTINGS_HEAD_ADDRESS() + address_offset + index] = filler[index];
JointController.cpp: In member function 'bool PLEN2::JointController::setMaxAngle(unsigned char, int)':
JointController.cpp:338:9: error: no match for 'operator[]' (operand types are 'EEPROMClass' and 'int')
JointController.cpp: In member function 'bool PLEN2::JointController::setHomeAngle(unsigned char, int)':
JointController.cpp:386:9: error: no match for 'operator[]' (operand types are 'EEPROMClass' and 'int')
Error compiling.Offline
Hi, Scriptwerx
I got the same error on Arduino IDE ver.1.7.9 created by arduino.org.
You could get Arduino IDE ver.1.6.8 created by arduino.cc from following link.
-> https://www.arduino.cc/en/Main/Software
Please ask us again when you have got an error using the IDE.
I can't get any software from arduino.cc to work with my current version of OS X El Capitan unfortunately.
The recent Arduino company split (.org and .cc) causes strange issues like this and it's quite annoying.
I'll switch to another machine with an older OS X and see how it goes with the arduino.cc software.
