#1 2018-01-06 15:36:49
MonkeyTurnip
Latest Build as an image file
Hi is there a newer version of the image file that 1380?
on this https://www.nanodlp.com/download/ the image file is 1380. i see in the build log thread it goes upto 1700, i would just like to use the latest version, but i seem to not be able to find a .img.
using a Wanhao D7 if that makes a difference.
TIA
MonkeyTurnip
#2 2018-02-21 14:37:13
miserovitch
Re: Latest Build as an image file
Same question for the same machine.
Hope we'll have some answer.
BR
#3 2018-02-22 01:47:53
elshad66
setup>> tools>>upgrade  nanodlp   --choose   beta   or   stabile version
wait 2-3 minutes PI update  and automatically reboot
latest   beta 1787
#4 2018-02-23 08:05:28
miserovitch
Thanks for the help.
I had issue with update. I solved it by accessing RPI through SSH and updating the hour (auto time adjust is not working...).
So now I have the last build...and another problem :-)
I will look in the forum, if I don't find I'l open a new topic.
LC
#5 2018-02-23 16:32:26
elshad66
1.   enter the router or modem and make the address pi static
2.   make the address PC  static
3.  Set your settings and options in the pi
4 .Download Windows 32bit version or Windows 64bit version. and run  only nanodlp.exe  (not necessary  settings and options)
5.  in  PI  --  setup  >>Remote Slicer  write IP  static  address PC   192.168.xxx.xxx:8080
6. Load STL model in PI
7 .if you want to update, do as you wrote above
