#1 2018-01-29 21:30:53
78ATI
Read (access) Layer properties
Hello!
maybe i will put a stupid question: there is a posibility to read two layers properties in the same time or at the same event?
(for example at "before every layer Gcode", i need to read the [[TotalSolidArea]] of layer nr 5 and [[TotalSolidArea]] of layer nr 4)
Thank you for your future answer!
#2 2018-01-30 05:27:31
Re: Read (access) Layer properties
Currently it is not possible.
#3 2018-02-02 17:40:57
78ATI
Thank you Shahin for fast answer! Can i ask you other related question:
How can i use [[SyscallResult]] in Dynamic cure process. I try {([[SyscallResult]]>3)*5}, but no value was calulated. in the GCODe before each layer, i can see the value of SyscallResault...but i don't know haw to pass it to dynamic cure time.
Thank you for your future feedback!
#4 2018-02-04 05:37:56
It is not possible to use  [[SyscallResult]] inside dynamic cure input. But you can use [[ExecReturn]] with the same effect.
