#1 2018-11-11 21:53:15
jb
Missing layer - NanoDLP Slicer
Hi everybody,
After my update on my last version of the NanoDLP Slicer, I got now some missing layer randomly...
I never change my machine setting or resin profile for 2 years and STL files stay the same.
Here some example :
Does anyone have the same problem? An idea of a solution?
Thanks all for your help & reply!
Jean-Baptiste
#2 2018-11-13 04:49:33
Re: Missing layer - NanoDLP Slicer
Please, share the STL file. It the most probably faulty triangle which affect slicer in special conditions. You can checkout the issue using netfab.
#3 2018-11-13 11:54:56
elshad66
Hello Shahin
I had cases when  (1956 build)
I put one element and copied to nanodlp  pressing C
creating multiple pieces(chains)
and came out the same problem as described above
item has been checked through  magics 20
then I just changed the position of the elements and everything was fine
but I had another problem
after upgrading to 1919, pi does not load the first time
the projector shows a red yellow green square
you need to restart 3-4 times, sometimes it does not help
sd card extract and insert helps sometimes
each time differently
DC  is stable, not lower than 5.1-5.2 volts
#4 2018-11-13 12:09:26
jb
Thanks for your rapid answer @Shanin.
I just send you an MP with a link of one STL. It's always repaired with netfabb...
Thanks again for your help! smile
#5 2018-11-14 09:33:32
uups
Hi. Shanin. Thank you for always.
I had a similar problem. So I would like to suggest one thing. Like creation workshop
Can I give options to slicers?
compound path
#6 2018-11-15 21:53:28
I do not know which option you are talking about.
