when im upload a stl or SLC file(new plates after update only), no information is displayed on "[ Toggle Details ] "???
Press CTRL+F5 to make sure resources are not cached if the issue continues let me know.
i have tried(stl binary,slc) upload again, with no success.
it seems that formula is being calculated, but theres no info from layers section
I guess you have pressed Toggle Details button right?
yes
Even rendered layer looks strange. Are you using direct control?
yes
all parts ( even with AA turned off) (bright-255) are reurning in half shade slices... its being an issue for me, and sensitive enough to 25µ pixel size, making dynamic cure not that eficiently
It could be a mask issue. Remove it see if rendering become normal
mask is turned-off
Share the STL file and debug file. I need to dig into it, never seen anything like this before.
The "halfshade" was mask issue, strange why its was activated, maybe accidently...i solved spherical distortions physically lens set, it was not required feature before, but some way i resolve to check anyway... thankyou
But the main issue still happening, the missing layering information inisde (Toggle Details) which we use to plan the strategy on formula box.
I export tha same stl both in ascii and bin versions, the same result.other files was test with slc too same results....
Do you still experience the same issue after slicing gets completed?
the layer half shade was a mask issue as you mentioned, i tested the ascii & bin, but still lacking the mesh area information
Try the beta version.
thank you!
