#1 2017-06-29 11:16:22
1125lbs
Build 1552 Issue on plate import
when im upload a stl or SLC file(new plates after update only), no information is displayed on "[ Toggle Details ] "???
#2 2017-06-29 20:25:20
Re: Build 1552 Issue on plate import
Press CTRL+F5 to make sure resources are not cached if the issue continues let me know.
#3 2017-06-29 21:20:20
1125lbs
i have tried(stl binary,slc) upload again, with no success.
it seems that formula is being calculated, but theres no info from layers section
#4 2017-06-29 21:30:37
I guess you have pressed Toggle Details button right?
#5 2017-06-29 21:31:34
1125lbs
yes
#6 2017-06-30 05:45:57
Even rendered layer looks strange. Are you using direct control?
#7 2017-06-30 05:55:33
1125lbs
yes
all parts ( even with AA turned off) (bright-255) are reurning in half shade slices... its being an issue for me, and sensitive enough to 25µ pixel size, making dynamic cure not that eficiently
#8 2017-06-30 06:12:33
It could be a mask issue. Remove it see if rendering become normal
#9 2017-06-30 06:15:44
1125lbs
mask is turned-off
#10 2017-06-30 06:24:24
Share the STL file and debug file. I need to dig into it, never seen anything like this before.
#11 2017-06-30 09:42:08
1125lbs
The "halfshade" was mask issue, strange why its was activated, maybe accidently...i solved spherical distortions physically lens set, it was not required feature before, but some way i resolve to check anyway... thankyou
But the main issue still happening,  the missing layering information inisde (Toggle Details) which we use to plan the strategy on formula box.
I export tha same stl both in ascii and bin versions, the same result.other files was test with slc too same results....
#12 2017-06-30 16:05:16
Do you still experience the same issue after slicing gets completed?
#13 2017-07-01 02:02:22
1125lbs
the layer half shade was a mask issue as you mentioned, i tested the ascii & bin, but still lacking the mesh area information hmm
#14 2017-07-01 05:55:38
Try the beta version.
#15 2017-07-01 13:33:50
1125lbs
thank you!
