#1 2016-11-27 21:15:28
DrNK
Viewsonic PJD7820HD additional commands
Could I add to the Switch projector On coomand another one to enable
Brilliant Color mode?
Even if set this preset in User 1 mode and save settigs, Brilliantcolor sets to the OFF after reboot.
Enable Brilliant Color 0x06 0x14 0x00 0x04 0x00 0x34 0x12 0x0F 0x01 0x6E
#2 2016-11-28 09:34:34
Re: Viewsonic PJD7820HD additional commands
Try [[Projector \x06...]]
#3 2016-11-28 10:14:49
DrNK
Yes, I know that it should be \x06\x14\x00\x04\x00\x34\x12\x0F\x01\x6E
but which field should I add this command?
FluxBB bbcode test
#4 2016-11-28 10:47:12
You should put it inside gcode box you found appropriate. I guess at the end of start/resume boxes (profile) will be ideal place.
#5 2016-11-28 11:13:37
DrNK
Like this? Doesn`t work
FluxBB bbcode test
This also doesn`t work
FluxBB bbcode test
#6 2016-11-28 12:39:20
No on gcode box you need to add following
[[Projector  \x06\x14\x00\x04\x00\x34\x12\x0F\x01\x6E]]
#7 2016-11-28 18:37:29
DrNK
Unfortunately it doesn`t work. Could you suggest the right field for that command?
Update Lamp Hours button in the Projector Calibration menu page doesn`t work also.
\x06\x14\x00\x04\x00\x34\x12\x0F\x01\x6E    Brilliantcolor on command
\x07\x14\x00\x05\x00\x34\x00\x00\x15\x01\x63      read lamp usage
#8 2016-11-29 10:31:56
DrNK
I`m still trying to find brilliantcolor mode working (+30% lumens)
FluxBB bbcode test
Help me please!
#9 2016-11-29 11:35:44
DrNK
Now it works
Error was with 2 spaces instead 1
How could I change command "update lamp time"?
#10 2016-11-30 20:23:44
DrNK
Original button "update lamp time" doesn`t change 0.000000 hours.
How could we solve it?
This is correct command
#11 2016-11-30 20:43:53
Try the beta version. There were a bug which thanks to Xmike, it has been solved.
#12 2016-11-30 21:56:12
DrNK
Do I need after upgrading to the beta make factory reset settings?
#13 2016-11-30 21:59:14
No you do not need
#14 2016-12-07 10:35:57
DrNK
Beta installed, but still Original button "update lamp time" doesn`t change 0.000000 hours.
#15 2016-12-07 12:13:12
Please, paste log output related to lamp hour here.
#16 2016-12-09 19:20:14
DrNK
Unfortunatelly Terminal window clear any information when input these projector Gcode commands.
[[Projector  \x07\x14\x00\x05\x00\x34\x00\x00\x15\x01\x63]]
FluxBB bbcode test
FluxBB bbcode test
#17 2016-12-09 21:13:37
Terminal page could be used to send command to RAMPS and not the projector.
Paste activity log on the dashboard.
#18 2017-01-13 18:38:31
DrNK
Notice    1    2017-01-13 18:32:27.191389    Projector    Following string from the projector received
Notice    1    2017-01-13 18:32:26.190633    Projector    Start reading lamp hours
Build 1326
Still Lamp Hours shows 0.000000Hours
Viewsonic PJD7820HD
Could you check it again?
I made custom button with same command [[Projector  \x07\x14\x00\x05\x00\x34\x00\x00\x15\x01\x63]]
There log with reply:
Debug    1    2017-01-13 18:36:19.467436    Gcode    Transfering Data to the Projector [92 120 48 55 92 120 49 52 92 120 48 48 92 120 48 53 92 120 48 48 92 120 51 52 92 120 48 48 92 120 48 48 92 120 49 53 92 120 48 49 92 120 54 51
#19 2017-01-13 18:55:31
Put  \x07\x14\x00\x05\x00\x34\x00\x00\x15\x01\x63 into Query Lamp Hours field on setup page and try again.
#20 2017-01-13 21:01:41
DrNK
These command from manual:
Lamp Time
Write Reset Lamp
usuage hour 0x06 0x14 0x00 0x04 0x00 0x34 0x15 0x01 0x00 0x62
Read Lamp usuage
hour 0x07 0x14 0x00 0x05 0x00 0x34 0x00 0x00 0x15 0x01 0x63
This command \x07\x14\x00\x05\x00\x34\x00\x00\x15\x01\x63  already in place more than 2 weeks but does not work
UNKNOWN    2017-01-13 20:52:28.594294 {"Layer":"50","module":"Projector","level":"Notice","msg":"Following string from the projector received "}
Notice    50    2017-01-13 20:52:27.593451    Projector    Start reading lamp hours
#21 2017-01-13 21:22:37
Have you tried turn on/off the projector through nanodlp?
#22 2017-01-13 21:46:48
DrNK
Yes, commands on/off and brilliant color work fine.
#23 2017-01-13 21:49:29
DrNK
Lamp Time
Write Reset Lamp
Read Lamp usuage
"Unknown" it was command switching projector menu to English language.
#24 2017-01-15 18:21:07
DrNK
The command is correct. Am I right?
#25 2017-01-15 20:41:16
No it means you have filled the correct input box and it try reading the value.
