HI Shahin
I have two printers with a ACERs of 1500 and 6510, with two absolutely identical PCs
they were never connected to the Internet, one WIN 7 64, another XP 32
older versions worked on them.all versions I threw a flash drive
I wanted to connect a pi and update it via the Internet, and all the win versions crashed,
WIN 7 64
old version writes "Initializing build # 0 - generic"
if click start display.,cursor disappears
if click LBM.,projector shines white
if click the button WIN on the keyboard ,and move the mouse to the monitor ,The cursor appears,
and through the projector calibration all works, but after 2-3 minutes again the projector is white
on the bottom panel writes nano dlp image viewer no answer
everything is exactly as happens on a laptop WIN 8 64
WIN XP 32
if click start display,monitor black
open only the start menu and the bottom panel, and the cursor is visible only on the bottom panel, and can only close,nanodlp.exe
Also does not work the new version 1744 on all PCs
before connecting to the Internet and updating everything was working fine
with CW all works.with pi all works but pi very slow,need a working win version
I will be very grateful how to solve this problem
Could you let me know previous version which worked fine? If you do not remember version, how old it was 2 3 months or older?
HI Shahin
I change the output of on a video driver ,on a computer that gave a black screen after the start (WIN XP32)
The first put the projector, the second monitor, and the monitor set the main
collected all the versions that I found on a computer and on a flash drive ,and one by one checked everything
those old versions that do NOT decrease on the first page, (where the log),,connection to the projector
If the click is start, the cursor appears in the center of the projector , and can be moved to the monitor, and all the calibration grids work,
and write "Initializing build # 0 - generic"
but other new versions that ,reduce, they do not work correctly,, after click start, the cursor disappears,and need to press the WIN on the keyboard
and all versions are written 1635,1647, 1686 ,1695 ,1739 1744,,while printing is not yet check ,,tomorrow I will check all versions on another computer
Thank you
HI Shahin
Now the older version works better if connect to the Internet,but if do not connect to the Internet, writes
Warning 0 Update Connectivity problem Get https://www.nanodlp.com/build.generic.txt: dial tcp: lookup www.nanodlp.com: no such host
but I do not know what version because,"Initializing build # 0 - generic",and in the old version there are no necessary parameters, which are in the new
is it possible in the new version,, make a connection to the display, as in the old?
Thank you
Elshad
I have checked out code, for a long time there were no major change to windows build. Mentioned error is not important.
Could you upload version which works fine with your computer?, so I could check out which build is it.
uploaded to my file exchanger
http://moemesto.ru/elshad666/files
still such a question , there are two the same pi ,on one 8GB ,on another 16 GB, both empty,
on that where 16, always writes
Free space available on your disk is low. Please remove some plates.
and on the other never, it was not written
16GB actually tested 14.8
as it is understood, if there is more
or as can increase this memory
thank you very much for your attention
Elshad
Thank you.
You need to expand SD card.
Have you tried latest version?
I have checked out difference since version was working and only things changed on gl module are mouse disabled on new version and go compiler upgrade. I can push versions without these features to see if it makes it work or not.
HI Shahin
I checked version 1751, and also does not work
after the start of the display need to press the WIN so that the cursor appears
I confirm the calibration, everything works, but through 2-3 minutes the projector is white,
video card driver updated
the bottom panel nano dlp image viewer no answer write
and another problem appeared
I tested different versions and each time different, a cube, a star, a triangle, a rhombus
in the latest version, tested the cone, and when I put a print on the test
then the screen on the first page comes out image, from other versions, and they change
one cube, the second star the third cone,
and further, vary in different ways
I opened all versions, and deleted everything plates
once again cut the cone
but image they come again
I scanned the computer all the files of png--nowhere is there anything
where to get these images nano ,I can not understand if I deleted everything
where is this file located
127.0.0.1:8080/static/plates/1/3.png
HI Shahin
maybe that I caught the virus and it all messed up
Can tell me where to get an older versions of nanodlp for Windows. I couldn't find it anywhere
Elshad
I thought you shared it above!
Please, download latest version see if it makes any difference.
HI Shahin
I formatted the computer and all cleaned,all previous versions collected in one archive
Did not connect to the Internet, installed everything through a USB flash drive,
and on a clean computer . I checked the latest version, can already print,there is already improvement but there is a small problem
if click start, the cursor appears in the center of the projector,and on the bottom panel flashes blue 7 times ''nanodlp image viewer". and stop fire blue color
Мove the cursor to the monitor, calibration works, and can print
if by any chance,mouse click will get on the projector or the blue ''nanodlp image viewer", calibration not works, and can"t print,,images do not go to the projector,,and ''nanodlp image viewer" ,how everything is gray
To continue working, need to restart nano.exe
Elshad
We can remove cursor but if you are using second display for your daily works, you would not have mouse cursor.
If you could put screenshots or video of what happening it will be quite useful.
HI Shahin
still found that
if gray ''nanodlp image viewer" and calibration not works
click start print and click ''nanodlp image viewer" ,it changes its color to white
and the image layers goes to the projector,if click on any part of the monitor, it changes its color to gray
and images layers do not go to the projector ,,''nanodlp image viewer" it works as an on / off switch
Elshad
HI Shahin
no need to remove the cursor ,, if you do not accidentally click on the projector or blue,,everything is working
on the first video
if click on the projector the same thing happens that click on the blue
Elshad
